09-14-2023 01:19 PM
I had AT&T Fiber installed this morning, they had to install the gateway on the 1st floor but they said I could now connect a line directly into my Ruckus switch for network but the switch isn't detecting anything. In addition, my access points mounted on the ceiling don't have any power (no lights flashing)
09-14-2023 02:00 PM
If you did do that and performed a factory reset, you likely need to reflash the firmware.
Download firmware from here: https://support.ruckuswireless.com/products/108-ruckus-icx-7150-campus-switches?open=software#sort=r...]
Follow these instructions: https://www.blackwiredesigns.com/ruckus-101/ruckus-icx-firmware-update-and-setup/
Let me know if you have any questions.
09-14-2023 03:26 PM
Trying this step now, I don't see a "power" button - trying this with the "re-set" button instead and then will try the software approach
09-14-2023 03:27 PM
Sorry, yes meant reset button not power button.
09-14-2023 06:59 PM
I tried to use a USB to ethernet adapter cable but I can't ID the Port and successfully launch putty
Are there technicians in the area that could help with this?
09-14-2023 07:00 PM
Where are you located?
