06-03-2025 08:53 AM
My Ruckus seems to no longer have power or connection to the hardwired ring doorbell, Smart Hub , Kevo.
I did not have any type of power outage or surge. I wonder if this is the end of life for this box? I had it since we bought the home (brand new Lennar home )
I have followed the directions to factory hard reset and that did not work. When I unplug the Ruckus box and plug it back in , there is a quick yellow flashing light, and then it goes blank and no lights come on after holding the paper clip for 15-20 seconds.
any other suggestions? is there anyone I can call to look at the devive, If not, I am looking to purchase another Ruckus or one of a similiar type .
06-03-2025 12:50 PM
Hello @kevensterner ,
Thank you for sharing the video and pictures.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
06-04-2025 08:55 AM
Thank you for sharing your response.
We’re pleased to hear that you’ve been in touch with our specialist team regarding the Switch replacement. The RMA team will reach out to you via email once the replacement has been processed. Typically, this will involve a direct replacement of the Switch.
You may have already received an email from the RMA team about the replacement. If you have any further questions, feel free to reply directly to their email.
06-03-2025 10:51 AM - edited 06-03-2025 10:59 AM
Hello Pinky.
Attached 2 Videos along with the yellow lights that flash after I plug it into the power outlet.
