03-16-2023 08:48 AM
Hello, in the past 2 years, the Ruckus switch has failed 3 times (all 3 in the past 7 months) it is currently out again, and I am unable to reset it. The model no. is ICX7150-C12P. I have tried resetting it. Frustrating as this keeps failing.
Thanks, Gopal
03-16-2023 09:18 AM
Hi @rama9998
Greetings of the day,
Please give the detailed description of the issue.
Please let us know how many access points are connected to the switch.
Is there any power outage recently?
Also please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
03-16-2023 09:52 AM
Appreciate the quick response.
I have 2 access points connected, both do not have any lights on
on the switch, I have SYST as yellow and PWR as green, no other lights.
There was no power outage.
03-16-2023 10:17 AM
Just to add, i have performed reset twice (once using the reset hole in the back, another time removing the power and reconnecting after a few minutes.
03-16-2023 10:22 AM
Hi @rama9998
Thanks for your reply,
We cannot replace the chassis until you confirm that the hardware is damaged.
Based on your description your switch has green and yellow light, which means that the switch is stuck in boot mode.
If the resetting process doesn't work, we need to perform a software recovery.
