Need help with icx 7150-c12p
Gabinhox
hello, I recently purchased a lennar home with an ruckus system model icx 7150-c12p.
i can see the wifi signal, connect to it but i dont get any internet. I need help setting it up, so i can use it and be able to change the name and pw for the wifi
5 REPLIES 5
Hi @Gabinhox
Thanks for your update,
And sorry for the late response,
As you have confirmed that the internet issue is stable while you are connecting to the ISP router, it looks like you switch(ICX7150 Switch) may be booting from the secondary partition (NOTE: Secondary partition contains the routing code) which is causing the bad connectivity issues.
Guide#1 for CLI:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
Guide#2 for CLI:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
How to Fix Routing code issues on Lennar Home users via Web GUI.
Note:  if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following image, ICX7150-C12-Router instead of ICX7150-C12-Switch, now before starting the steps of the guide, I will advise you to cable the computer directly to the Switch, since you will have a better connectivity than if you connect via wireless.
.After fixing the issue of the Switch booting from the wrong partition, please perform an upgrade to the code 08095g UFI and upgrade both partitions primary and secondary with the switching code file named SPS08095gufi.bin, take into consideration that is the Switch is running a code lower than 08080 you need to upgrade twice, from the code you are to 08080f and then the recommended code 08095g UFI.
Upgrade a switch via Web GUI (ICX7150 Switch)
