06-24-2025 08:30 AM
I have plugged my xfinity router into the Ruckus base. What are the next steps that I need to take in order to light us the Ruckus wireless network?
06-25-2025 01:15 PM
Hey Imran, if I am connected to the Configure.Me network I can log into the unleashed app and see the WLAN. Two things, there is no internet connection even though I have plugged in my xfinity router that has internet access. And also the Ruckus network show No (0) APs, even though they are all lit green.
06-25-2025 01:22 PM
Hi @Graham75
Please confirm if you completed the steps explained in the video.
If not, please do it using a Laptop and complete the reset process.
Thank you again.
06-25-2025 02:13 PM
I can't use a laptop. When i connect to the Configure.Me network I can't get to unleashed.ruckuswireless.com becuase it doesn't have internet access. Is there anyway we can just jump on the phone? This is getting frustrating. I just need to talk to someone and it will probably get resolved alot more quickly.
06-26-2025 05:25 AM
Hi @Graham75
We apologize for the inconvenience.
You can access https://unleashed.ruckuswireless.com/ without an active internet connection on your laptop by connecting to the Configure.me-xxxxxxxx network.
If you continue to experience issues, please try disconnecting the current Access Point (AP) from the switch port. Then, connect a different AP and attempt a factory reset on the newly connected AP. Only ONE AP must be connected to the Switch port during this process.
Please note that, effective November 2022, RUCKUS Support for Lennar Homes customers is no longer provided via phone, email, or remote session. All support is now exclusively offered through this community forum, on a best-effort basis.
If you’re still facing challenges following the above steps, we recommend reaching out to a local technician for further assistance, as RUCKUS does not provide on-site technician support for Lennar Homes.
Should you need assistance with the upgrade process, feel free to let us know—we’re here to help.
06-26-2025 08:00 PM
Imran, it will not allow me to connect on my laptop or any other laptop. Can you give me the contact info for a local technician? This mode of support is not helpful.
