09-30-2024 06:15 PM
Need assistance with upgrading switch ICX7150-C12P firmware version
10-01-2024 05:00 AM
Hi @eyumalai
Based on the information provided, it appears that you need assistance in upgrading your RUCKUS ICX-7150-C12P Switch to the recommended firmware version.
Before I assist you with the Switch upgrade, could you please let me know the current version of your Switch?
Please follow the steps below to check the Switch version using the command line.
Please follow the steps outlined below to access the Command Line Interface (CLI) and provide the necessary command outputs:
1. First, identify the current IP address assigned to the switch ICX-7150-C12P by your local router. You can use an IP scanner tool to easily locate the switch's IP address on your network. Here is a guide on how to perform this using IP Scanner free applications:
2. Once you have identified the IP address of the switch, proceed to access the Command Line Interface (CLI) of the RUCKUS ICX-7150-C12P switch. Here is a guide on how to access the CLI:
If you can access the Command line the prompt should look like the below:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
3. After successfully accessing the CLI, please execute the following commands and provide the outputs:
show version
show flash
show inline power
show inline power detail
show interface brief
Please share the command outputs or screenshots if you encounter any issues or errors during these steps.
10-03-2024 05:05 AM
Hi @eyumalai
I kindly request an update on the status of the issue so that we may proceed further with resolving it. Pleas help me with the requested queries from my last post.
Thank you.
10-04-2024 05:09 AM
Hi @eyumalai
Thank you.
10-07-2024 05:27 AM
Hi @eyumalai
Thank you.
