01-29-2024 10:56 AM
I’m so tired of spending hours after hours to get the switch works after each power outage. It’s completely down this time. I’ve reviewed the knowledge articles and there’s no way I can complete the task nor I don’t have a Ethernet-abled laptop. Respectfully request a replacement switch with the stabled image version that I don’t need to worry about the power outage ever.
02-01-2024 07:08 AM
Hi @Hugpinapple
Thanks for your response,
Based on the troubleshooting done, tried unplugging and plugging the switch several times seems that the management port is not responding this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
01-30-2024 09:09 AM
New issue experienced. Cant build connection between laptop and switch per instruction. My port is COM5(also tried all the rest ports), putty won’t shows anything once excuted.
01-30-2024 09:12 AM
Hi @Hugpinapple
Please try to connect the ethernet cable to the ethernet port on the switch and the laptop as mentioned below. Ethernet cable connected between the Out-of-band management port in the Switch to your computer Ethernet port.
If you don't have ethernet ports on your laptop please try to get a laptop which has ethernet ports and make the connection.
01-30-2024 09:18 AM
So I unplugged the switch and replugged back while the cables and putty connected. This is what I got in putty.
01-30-2024 09:55 AM
Hi @Hugpinapple
Please check the connections again from the switch to your laptop and reconnect it. Also please try to connect the ethernet cable to the ethernet ports on the switch and the laptop as mentioned below.
01-30-2024 11:11 AM - edited 01-30-2024 11:12 AM
I changed a different laptop with Ethernet port, and it still can’t connect.
