My Ruckus ICX-7150-C12P does not power on
Songbird52
My Ruckus ICX-7150-C12P does not power On
7 REPLIES 7
Imran_ruckus
Hi @Songbird52
Thank you for providing the information.
Based on the details you've shared, it appears that your RUCKUS ICX-7150-C12P Switch is not operational.
Could you please let me know if you tried to power it up using a different working power cord with different working power outlets? If no, please try it once.
If that doesn't work even with a working power cord, I recommend attempting a physical factory reset multiple times, as outlined in our RUCKUS Lennar Knowledge Base self-help article accessible through this link and VIDEO:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
Video link: https://www.youtube.com/watch?v=6jHMTdo_hK4
If the initial reset attempts do not resolve the issue, please try resetting your switch multiple times (approximately 10-15 times) using the method described in the article. In some cases, repeated attempts have successfully resolved similar issues. Upon successful reset, the SYST and PWR lights should turn GREEN.
Please proceed with these steps and let me know if the switch powers on successfully afterward.
Thank you for your patience and cooperation in this matter.
Imran_ruckus
Hi @Songbird52
Thank you.
Hi, good day.
No luck with resolving issue .
Intermittently it would shut off and not come back on for days.
Now  It has been off for five days straight.
I tried several resets and I used different outlets and nothing works..
Hi @Songbird52
