My ICX-7150 C12P switch is dead. No lights
davidswilson
My ICX-7150 C12P switch is dead. No lights.
Hello Support Team,I own a Ruckus ICX 7150-C12P and a WAP through Lennar. My switch is not powering on at all. When I plug it in, the amber light flashes briefly, then the unit shuts off completely, and no lights remain on. There have been no power
Remove power from the switch.
Press and hold the reset button while applying power to the switch.
Release the reset button after all of the system LEDs are not turning on
SN:- ***********
Product Name: 12-PRT POE+ COMP 2X1G SFP+
Product Family: ICX Switches    Product Code Part: C12P
Warranty Expires: January 15, 2031
Edit: some information removed for security reasons - admin
25 REPLIES 25
lights are not coming up
Hi @davidswilson
Thank you for your recent correspondence and update.
We may need to check some configurations of your RUCKUS ICX-7150-C12P Switch to troubleshoot this issue.
To proceed with troubleshooting the issue, please follow the steps outlined below to access the Command Line Interface (CLI) and provide the necessary command outputs:
1. First, identify the current IP address assigned to the switch ICX-7150-C12P by your local router. You can use an IP scanner tool to easily locate the switch's IP address on your network. Here is a guide on how to perform this using IP Scanner free applications:
2. Once you have identified the IP address of the switch, proceed to access the Command Line Interface (CLI) of the RUCKUS ICX-7150-C12P switch. Here is a guide on how to access the CLI:
If you can access the Command line the prompt should look like below:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
3. After successfully accessing the CLI, please execute the following commands and provide the outputs:
   show version
   show flash
   show inline power
   show inline power detail
   show interface brief
Please share the command outputs or screenshots if you encounter any issues or errors during these steps.
Hi @davidswilson
Thank you.
Hi @davidswilson
Thank you.
Hi @davidswilson
Thank you.
