07-17-2023 04:18 PM
Lennar home owner with a Ruckus. The light on our system isnt lighting up. How do I confirm that my Ruckus system is working and working optimally? I am not a techy so not 100% sure how it works. Any help would be appreciated.
07-17-2023 04:36 PM
Hi @CaptDianabol
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working.
1. Was this working before? If it worked before, was there any power outage before you started facing this issue?
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
