01-09-2023 11:16 AM - edited 01-09-2023 11:54 AM
I am trying to connect to the Ruckus R320 and I do not see the Configure.me or the Lennar wifi networks available to connect to. I have unplugged and replugged in the power box in the laundry room. Two green lights are showing up at the Access Points first one is blinking, second one is solid, no other lights are on.
01-09-2023 12:17 PM
Hi @JenD
Please share the below details for better understanding of the issue.
01-09-2023 12:37 PM - edited 01-09-2023 12:38 PM
I do not have a lot of tech experience.
1. How do I check the firmware version?I can't get setup on Unleashed because I can't see the Configure.Me wifi.
2. How do I SSh into the AP? I have Windows 11, do I use command prompt? Do you have more detailed insturctions?
3. I have two AP's, does that mean I use groups?
Thank you for any further details you can provide me.
01-09-2023 01:02 PM
Hi @JenD
Thanks for the information provided.
Please follow the below steps to unhide SSID.
We can access to AP GUI, do the following operation to unhide the SSID:
Go to Configuration > Radio 2.4G, find what you want to hide the SSID, click it.
In the Broadcast SSID Section, select Enable.
and then click Update Settings, You can find this SSID is broadcast.
We could also hide or unhide the SSID from the controller CLI using the below set of commands,
ruckus# config
ruckus(config)# wlan <WLAN name>
ruckus(config-wlan)# no hide-ssid
The command was executed successfully.
01-09-2023 01:13 PM
I tried putting ruckus# config in command prompt and it says it is not recognized.
Where do I go to get to Go to Configuration > Radio 2.4G?
Thank you
