Lennar house with Ruckus r510 and ICX 7150 C12P not connected at 1000-Full
robert_moua
Hi. I bought a Lennar home and it came pre-installed with Ruckus r510 and ICX 7150 C12P. I'm getting around 100 Mbps from speed tests while on the r510. However, on my Asus, I'm pulling around 580 Mbps. I believe the issue is that I'm uplinked from the r510 to the ICX at 100 Full.  I can't seem to change the NIC port speeds on my r510 to 1000 Mbps Full. Below are the CLI output from the r510 and ICX. The r510 is connected to port 1/1/1. Port 1/1/3 is uplink to my AT&T modem. I'm running 200.6.10.1.312 on the r510.
telnet@ICX7150-C12 Switch#sh int brief
Port       Link    State   Dupl Speed Trunk Tag Pvid Pri MAC             Name
1/1/1      Up      Forward Full 100M  None  No  1    0   c0c5.2093.a943
1/1/2      Down    None    None None  None  No  1    0   c0c5.2093.a944
1/1/3      Up      Forward Full 1G    None  No  1    0   c0c5.2093.a945
1/1/4      Down    None    None None  None  No  1    0   c0c5.2093.a946
1/1/5      Up      Forward Full 100M  None  No  1    0   c0c5.2093.a947
1/1/6      Down    None    None None  None  No  1    0   c0c5.2093.a948
1/1/7      Down    None    None None  None  No  1    0   c0c5.2093.a949
1/1/8      Up      Forward Full 100M  None  No  1    0   c0c5.2093.a94a
1/1/9      Up      Forward Full 100M  None  No  1    0   c0c5.2093.a94b
1/1/10     Up      Forward Full 100M  None  No  1    0   c0c5.2093.a94c
1/1/11     Down    None    None None  None  No  1    0   c0c5.2093.a94d
1/1/12     Down    None    None None  None  No  1    0   c0c5.2093.a94e
1/2/1      Down    None    None None  None  No  1    0   c0c5.2093.a950
1/2/2      Down    None    None None  None  No  1    0   c0c5.2093.a951
1/3/1      Down    None    None None  None  No  1    0   c0c5.2093.a952
1/3/2      Down    None    None None  None  No  1    0   c0c5.2093.a953
mgmt1      Down    None    None None  None  No  None 0   c0c5.2093.a943
ruckus> en
ruckus# show config
Protocol Mode= IPv4-Only
Device IP Address:
  Mode= DHCP
  IP Address= 192.168.1.70
  Netmask= 255.255.255.0
  Gateway Address= 192.168.1.254
  Primary DNS= 192.168.1.254
  Secondary DNS=
Country Code:
  Code= United States
Identity:
  Name= Ruckus-Unleashed
Session Statistics:
  Enable= false
  Limited Unauthorized Session= true
NTP:
  Status= Enabled
  Address= ntp.ruckuswireless.com
  Timezone= GMT
Log:
  Status= Disabled
  Address=
  Facility=
  Priority=
  AP Facility=
  AP Priority=
  event log level= 1
Bonjour Service:
  Status= Enabled
Telnet Server:
  Status= Disabled
FTP Server:
  Status= Enabled
  Anonynous Status= Disabled
Unleashed Multi-Site Manager:
  Status= Disabled
  Address=
  Interval= 3
login warning:
  Status= Disabled
  content= "Warning, you are logging into device for authorized user only. If yo        u are not an authorized user, please click Quit; otherwise click Continue to log        in."
LWAPP:
  MGMT queue length threshold to drop AUTH frame = 100
  MGMT queue length threshold to resume processing AUTH frame = 25
EAPoL Key no Retry:
  Status= Disabled
Unleashed Network:
  Token= un1619020082171532588476075
AAA:
  ID:
    1:
      Name= Local Database
      Type= Local
    2:
      Name= Guest Accounts
      Type= Guest
DHCP servers for DHCP relay agent:
Administrator Name/Password:
  Name= admin
  Password=
  Authenticate:
    Mode= Authenticate using the admin name and password
Management ACL:
AP:
  ID:
    1:
      MAC Address= 1c:3a:60:36:ae:d0
      Model= r510
      Approved= Yes
      Device Name= RuckusAP
      Device Role= Master
      Description=
      Location=
      GPS=
      CERT = Normal
      Bonjour-policy=
      Bonjour-fencing=
      Group Name= System Default
      Channel Range:
        A/N= 36,40,44,48,149,153,157,161 (Disallowed= )
        B/G/N= 1,2,3,4,5,6,7,8,9,10,11 (Disallowed= )
      Radio a/n:
        Channelization= Auto
        Channel= Auto
        WLAN Services enabled= Yes
        Tx. Power= Auto
        WLAN Group Name= Default
        Call Admission Control= OFF
        Protection Mode= Auto
      Radio b/g/n:
        Channel= Auto
        Tx. Power= Auto
        Protection Mode= 2
      Override global ap-model port configuration= No
      Network Setting:
        Protocol mode= IPv4-Only
        Device IP Settings= DHCP
        Gateway= 0.0.0.0
        Primary DNS Server= 192.168.1.254
        Secondary DNS Server=
      Mesh:
        Status= Disabled
      LLDP:
        Status = Use Parent Setting
      LAN Port:
        0:
          Interface= eth0
          Dot1x= None
          LogicalLink= Up
          PhysicalLink= Up 100Mbps full
          Label= 10/100/1000 PoE Port1
        1:
          Interface= eth1
          Dot1x= None
          LogicalLink= Down
          PhysicalLink= Down
          Label= 10/100/1000 Port2
      PoE Mode= Auto
Smart Redundancy:
  Status= Disabled
  Peer IP/IPv6 Address=
  Shared Secret=
IPv4 Management Interface:
  Status= Disabled
  IP Address=
  Netmask=
L2/MAC ACL:
  ID:
    1:
      Name= System
      Description= System
      Restriction= Deny only the stations listed below
      Stations:
SNMP Agent:
  Status= Disabled
  Contact=
  Location=
  RO Community= public
  RW Community= private
SNMP Trap:
  Format= Version2
  Status= Disabled
SNMPV3 Agent:
  Status= Disabled
  Ro:
    User=
    Authentication Type= MD5
    Authentication Pass Phrase=
    Privacy Type= DES
    Privacy Phrase=
  Rw:
    User=
    Privacy Type= DES
    Privacy Phrase=
SNMP Trap:
  Format= Version3
  Status= Disabled
WLAN Service:
  ID:
    1:
      NAME = House14
      Tx. Rate of Management Frame(2.4GHz) = 2.0Mbps
      Tx. Rate of Management Frame(5GHz)   = 6.0Mbps
      Beacon Interval = 100ms
      SSID = House14
      Description = House14
      Type = Standard Usage
      Authentication = open
      Encryption = wpa2
      Algorithm = aes
      Passphrase =
      FT Roaming = Disabled
      802.11k Neighbor report = Disabled
      Web Authentication = Disabled
      Authentication Server = Disabled
      Accounting Server = Disabled
      Called-Station-Id type = wlan-bssid
      Tunnel Mode = Disabled
      DHCP relay = Disabled
      Max. Clients = 100
      Isolation per AP = Disabled
      Isolation across AP = Disabled
      Zero-IT Activation = Disabled
      Load Balancing = Enabled
      Band Balancing = Enabled
      Dynamic PSK = Disabled
      Auto-Proxy configuration:
        Status = Disabled
      Inactivity Timeout:
          Status = Disabled
      VLAN-ID = 1
      Dynamic VLAN = Disabled
      Closed System = Disabled
      Https Redirection = Disabled
      OFDM-Only State = Disabled
      Multicast Filter State = Disabled
      802.11d State = Disabled
      Force DHCP State = Disabled
      Force DHCP Timeout = 0
      DHCP Option82:
          Status = Disabled
          Option82 sub-Option1 = Disabled
          Option82 sub-Option2 = Disabled
          Option82 sub-Option150 = Disabled
          Option82 sub-Option151 = Disabled
      Ignore unauthorized client statistic = Disabled
      STA Info Extraction State = Enabled
      BSS Minrate = Disabled
      DTIM period = 1
      Directed MC/BC Threshold = 5
      Call Admission Control State = Disabled
      PMK Cache Timeout= 720 minutes
      PMK Cache for Reconnect= Enabled
      NAS-ID Type= wlan-bssid
      Roaming Acct-Interim-Update= Disabled
      PAP Message Authenticator = Enabled
      Send EAP-Failure = Disabled
      L2/MAC = No ACLS
      L3/L4/IP Address = No ACLS
      L3/L4/IPv6 Address = No ACLS
      Precedence = No ACLS
      Proxy ARP = Disabled
      Device Policy = No ACLS
      Vlan Pool = No Pools
      Role based Access Control Policy = Disabled
      SmartRoam = Disabled  Roam-factor = 1
      White List = No ACLS
      Application Recognition & Control = Disabled
      Apply ARC Policy = NO POLICY
      Client Flow Data Logging = Disabled
      Wlan Bind = all
WLAN Group:
  ID:
    1:
      Name= Default
      Description= Default WLANs for Access Points
      WLAN Service:
        WLAN1:
          NAME= House14
          VLAN=
8 REPLIES 8
hayward_kong
Contributor III
Personally, I think the termination that goes to the R510 is bad or the one going to the switch is bad. I rarely see a R510 or any ruckus AP that is defective. ... but yeah I would first unmount the R510 and test it with a known good cable.
hayward_kong
Contributor III
you can always call Lennar home builder and explain that it could be cable or it could be the R510.... My bet it's the cable..
robert_moua
So a bit of investigating and moving the r510 around, it was a bad cable. The issue was throwing me off since I have another r510 that has a dead PoE port but works with AC and NIC port 2. I'm now showing 1000 Full on each AP with workaround. I will have to reach out to Lennar/Ruckus on RMA the bad r510 and fixing the house wiring. Thanks for all the help.
hayward_kong
Contributor III
No problem, but stick with firmware 200.6 for now til ruckus fixes a encryption issue with iOS devices.
