11-28-2022 07:08 AM
Does anyone know how to get power back to the ceiling boxes. The forums instructions are far too technical. My boxes have been down since 11/25.
11-25-2022 03:52 PM
Both my ceiling boxes have no lights after a power outage.
11-25-2022 04:13 PM - edited 11-25-2022 04:16 PM
Hi @SenderoJ
Thank you for the details provided, according to your description, it seems that your Switch (ICX7150 Switch) may be stuck in boot mode, so in order to fix it, you need to get access via console, using two connections one is for console access using the USB to type C cable (the USB will be connected on your computer and the type C on your ICX7150 Switch) now the second connection will be an Ethernet cable from your computer to the out-of-band port on your ICX 7150 Switch). Don't worry, the next guide explains the port locations and there are pictures about it.
1:Try first the factory reset:
Ruckus ICX 7150/7650 -ERASE SYSTEM TO FACTORY DEFAULT WITH RESET BUTTON(Tutorial video)
https://www.youtube.com/watch?v=6jHMTdo_hK4&t=1s
2:IF the issue persisted, followup the next guide.
Yarenis Hernández
11-28-2022 09:05 AM
Hi @SenderoJ
Thank you for the details provided, according to your description, it seems that your Switch (ICX7150 Switch) may be stuck in boot mode, so in order to fix it, you need to get access via console, using two connections one is for console access using the USB to type C cable (the USB will be connected on your computer and the type C on your ICX7150 Switch) now the second connection will be an Ethernet cable from your computer to the out-of-band port on your ICX 7150 Switch) don't worry the next guide explains the port locations and there are pictures about it.
Note: These will be the Symptoms, and please read the guides carefully before start the troubleshooting.
*The Switch will not provide power to any PoE devices (Doorbell, cameras, even the Access Points).
*Will not have connectivity to the devices connected to the Switch.
*The ISP router will work fine.
*Console access will be the only access available.
*System light will be yellow/orange/Amber.
How to perform a Software recovery on an ICX7150 switch.
Yarenis Hernández
11-28-2022 10:58 AM
The device is no longer providing or supplying to Wireless Access Points.
