09-06-2024 06:57 AM
I have an issue with my switch ICX-7150-C12P. I just recently moved to Lennar home. My APs are not wirking and switch is having orange light for SYS and green light for PWR. I tried reset it, probably, 5 times, it's just keep blinking orange, even left it overnight (following reset steps here https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy... ) then I tried connect to it using Ethernet or/and usb-C with my MacBook, following steps described here https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-71.... Please help
09-06-2024 07:50 AM
Hi @Vladk
Based on the information provided, it appears that your RUCKUS ICX-7150-C12P Switch is stuck on boot mode with Amber SYST.
Please attempt a hard reset using a paperclip 10-15 times. If this does not resolve the issue, the next step would be to perform a software recovery on the Switch. For detailed instructions on this process, please refer to the following RUCKUS Lennar Knowledge Base article:
Fixing RUCKUS Switch with an Amber/Orange Light on "SYST"
To access the Console, please make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file, the driver should be installed using the 2 links below.
Link 1: https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Link 2: silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
Please check and let me know if that works.
09-06-2024 02:12 PM
Hello Imran, hard reset didn't work for me as I mentioned earlier and I can't connect to a console via ethernet nor usb-c. What would be my next steps?
09-06-2024 06:14 PM
Hello, hard reset didn't work for me as I mentioned earlier and I can't connect to a console via ethernet nor usb-c. What would be my next steps?
09-06-2024 09:23 PM
anyone had any success with this. I tried multiple reset but just keep blinking all the light. and downloaded the driver from above link and connected console port on 7150 using rj45 to usb A on windows laptop but unable to connect using putty to console.
