06-07-2023 10:34 AM
#FEK3827R077
IMO, a very unorthodox method to get customer support on a failed device. Nonetheless, here I am.
Heartbeat loss multiple times a day.
WAPs lose power.
No internet connection.
Connected devices unable to be accessed remotely due to 'no connection'.
Only been a my home for 2.5 years.
The company that installed the system, Connect Source, say that I NEED A NEW SWITCH.
Please advise.
06-09-2023 08:17 AM
admin test
06-09-2023 08:21 AM
Hi @StevenG3000
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, with no Internet connection.
1. Was this working before? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same showing the light status and the cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
06-11-2023 05:47 AM
Answers to questions below.
1. Yes
2. PWR, SYST, STAT all green
3. Yes
4. 2 Click link for pictures
4a. https://drive.google.com/file/d/1_8zK6SSvakRnNdhAsWc9YNvnFJ596fkv/view?usp=sharing
4b. https://drive.google.com/file/d/1_3RqN3Nio_oyUHFniqCLYbhZFWC9czaI/view?usp=sharing
06-12-2023 09:36 AM
Hi @StevenG3000
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
