12-09-2023 10:58 AM
I am using the Ruckus ICX 7150 with access points that came with my new Lennar home. The switch is not powering up now and my AP’s and Ring door bell do not work as the POE ports are not working. The community search provides a resolution to this problem which is to replace faulty equipment under lifetime warranty. Can a technical support engineer please approve the RMA for Case#01603412.
Thank you.
Gautam Dharmapuri
12-10-2023 08:06 AM
Hi Madhugaut
Thank you for reaching us
Apologies, effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email or remotes session. We will be exclusively supporting customers via this community forum support model only. You can always feel free to reach us on portal with any concerns you have.
As per the details provided I understand that your RUCKUS setup is not working.
Could you please let us know the below details to understand the issue better ?
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
12-10-2023 11:37 AM
Hi Chandini,
1. The switch and 2 WAPs were installed in my new home and have been working for 5 years now.
2.The problem with the ruckus switch is that it doesn’t power up anymore. When I reconnect to power four lights blink once in amber color and no power after that. We have 2 WAPs which do not power as there is no power from the switch.
3. I have a stable internet connection which is working with the connected wifi router.
4. I have 2 WAPs and nothing works.
12-11-2023 07:15 AM
Hi @madhugaut
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
Have you tried using a different power cord, in case the current power cord is damaged?
If yes, Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and working power outlet? Please refer to the below pictures as an example.
