06-08-2023 08:28 AM - edited 06-08-2023 08:34 AM
Hi
My ruckus system is not powering up , we do not have any lights in Ruckus ICX 7150 and in any APs. I have already tried multiple attempts to reboot whole system but nothings seems to be working. Please check below pictures for more details. Please help me fix this or guide me to right direction how i can resolve this.
Thank you in advance !
06-09-2023 03:12 PM
Hi @hdiyora
Greetings of the day!!!
Thank you for sharing the requested information and a video.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, Also, you tried to reset the Switch and you confirmed that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
06-08-2023 09:28 AM
Hi @hdiyora
Hope you are doing well!!!
From the case description, I could understand that your RUCKUS ICX-7150-C12P Switch and Access Points are not powered on.
Did you try to reset the Switch with a paperclip? If not, please refer to the below process.
First, we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
Also please try to check by replacing another Power cord with the Switch. In case the current Switch power cord is damaged.
06-08-2023 03:10 PM
Hi Imran,
Thank you !
I have followed above instruction 4 to 5 times but ICX-7150 is still not booting up. Reset doesn't seems to be working, what can i do at this moment ? i do work from home and it is causing lots of issues.
06-08-2023 03:57 PM
Hi
Did you try to check by replacing another Power cord with the Switch. In case the current power cord had damaged?
If yes, could you please plug your ICX-7150-C12P Switch into a working power outlet and send us a PICTURE and VIDEO of it showing the light status, and cord connected to the Switch and working power outlet? Please refer to the below pictures as an example.
06-09-2023 02:37 PM
Hi Imran,
I have followed all the steps as per your suggestion but still no luck. Also uploaded video file to above link. Please check that
