Internet very weak after power outage
Roshan_90
Yesterday I had a power outage and then Internet back very weak doesn’t load any Video or open the tv please help
4 REPLIES 4
pinky_ruckus
Hi @Roshan_90 ,
From the case description, I understand that you are facing slow speed issues after the power outage.
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is running in the Routing code.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-ICX-7150-C12P-...
Please follow the process as explained in the article and let me know if you have any queries in this regard.
pinky_ruckus
Hello @Roshan_90 ,
pinky_ruckus
Hello @Roshan_90 ,
pinky_ruckus
Hi @Roshan_90 ,
Thank you.
