Internet interruptions/buffering since power cycling Ruckus unit
vsood1
Last week I power cycled my ruckus unit and since then I have been having internet interruptions or extremely slow speeds. I had xfinity tech come over and they did not find any issues with the modem. I tried to follow other similar posts and tried to find the ruckus switch ip using the "LanScan" app on my Mac. I see 2 IPs listed as "Ruckus Wireless", but I believe those are the IPs for the APs and not the switch... the mac address for the IPs does not match the MAC address of the switch.
Will it be possibel to get on a call with someone... I am really having interruptions with my work.
1 ACCEPTED SOLUTION
vsood1
Things are stable and look good. Thanks for the suppport.
29 REPLIES 29
Imran_ruckus
Hi @vsood1
As per the case description, I understand that you have an intermittent Internet connection via your RUCKUS network setup.
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless OR Brocade Communications to confirm the IP address of the Switch and access the CLI.
vsood1
I see the MAC address of the switch in the LanScan app results. The IP listed is 192.168.1.3 with name Ruckus Wireless. There is "Ping" column in LanScan and it is showing red circle. Also tried on the browser ... i see this:
This site can’t be reached
http:// 192.168.1.3  is unreachable.
ERR_ADDRESS_UNREACHABLE
How can I paste images in a post here? Will it be possible to connect over ph to resolve this, it is causing lotta issues for me.
Hi @vsood1
1. Could you please share the screenshot of the IP Scan results?
2. Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports.
3. Could you please try to IP Scan on a Windows Laptop/PC?
Please let me know the answers to ALL the above queries or let me know if you have any queries in this regard.
vsood1
Things are inconsistent... I ran the scan again and I see the same IP and now able to access via browser and see the screen you pasted. How do I open a command shell to the switch on MAC?
i also tried "telnet 192.168.1.3", but looks like port 23 is not available on the switch.
