08-27-2024 01:46 PM
My internet doesn't work when connected through the ruckus access point I set up. However, it does work when I use the ethernet cable directly from the ICX switch or router. My internet also works connecting directly to my router from the provider.
All of the lights are green on the ICX switch and I have all ethernet cables plugged into 1 of the 12 ports.
The lights are all green on the AP as well.
This worked until I switched providers and I couldn't get it to work again. I'm not sure what changed.
Thank you
08-27-2024 04:02 PM
Hi @chef_boy_r_G ,
From the case description, I understand that you are facing issues connecting to Internet when connected with AP.
Before we can help, we need to check which version the Switch is currently running.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
08-28-2024 09:27 AM
Hello @chef_boy_r_G ,
09-02-2024 07:29 AM
09-04-2024 08:59 AM
Hi @chef_boy_r_G,
Thank you.
