โ02-15-2024 06:51 AM
Good morning,
I have AT&T gateway supplying a Ruckus switch which then supplies a Ruckus R320 AP. The AP appears to be behaving intermittently. When I connect via phone or on another device the pages freeze then load after 5-10 seconds. I have also performed speed tests comparing the R320 AP to the AT&T gateway and the results vary. I requested a new AT&T gateway which I installed last night and the issue has not been resolved. Please advise next steps in resolving, thank you!
โ02-15-2024 07:17 AM - edited โ02-15-2024 07:59 AM
Hello @dreyes1113
Hope you are doing well ,
If your home experienced a power outage, it's likely that your switch began operating with routing code this can be fixed.
To temporarily resolve this, I recommend connecting to your local router via Ethernet or Wi-Fi. This approach should alleviate any current connectivity issues.
We need to attempt accessing the switch. I will provide a guide outlining various methods to rectify this issue and detailed steps for gaining access to the unit.
Here is a link how to resolve this problem and detail explanation :
Furthermore, entering either 192.168.0.254 or 192.168.1.254 into the URL bar of a computer connected to the AT&T network should direct you to the AT&T router interface. There, you'll find a 'Device List' tab, which will help you locate the IP of the switch to address this issue
Best Regards
Fernando Vasquez
โ02-15-2024 07:33 AM
Fernando,
What if I do not have the ability to download the CLI to reboot the switch? My company laptop is preventing me from doing so.
Hello @dreyes1113 ,
There's a portable tool available that performs the same functions, which might be a feasible option for you.
https://mobaxterm.mobatek.net/download-home-edition.html
However, if that's not possible, I would suggest using a borrowed computer as an alternative solution.
Best Regards
Fernando Vasquez
โ02-15-2024 10:27 AM
I am getting "Network Error: Connection Refused" when trying to use the Putty application
