ICX7150 Switch routing code issue, slow and intermittent internet
asaad1972
I have issues with my Ruckus network. I had a power down issue and Cox issues. Now my Cox network works fine but my Ruckus network has many issues. Internet is very slow or not working at all. My Unleashed app is showing ICX7150-C12-Router and "connecting (discovery)" with red font.
I read many other forums that all point to the routing code issue. I tried to connect with a Putty command line to my switch but the CLI doesn't accept the commands listed on other forums, such as "show flash", "copy flash flash secondary", "boot system flash secondary yes". I am attaching a screenshot of my Putty CLI window.
I see 3 IP addresses for Ruckus Wireless since I have one switch and two APs. One IP doesn't connect while the second doesn't accept the "enable" command. The third one is the one that I am showing the screenshot from above.
I also tried to connect to the switch with a USB cable but I couldn't find instructions to connect with the serial interface.
Please advise on how to reconfigure the switch out of this Routing mode.
Ashraf
1 ACCEPTED SOLUTION
Hi @asaad1972
The Unleashed dashboard appears to be functioning normally based on the screenshot you provided.
Please let me know if you encounter any issues with connectivity or performance.
42 REPLIES 42
Hello @asaad1972
It appears that the Access Points (APs) are now functioning normally. The observed speed variations may be attributed to several factors, such as RF interference and the distance between the device and the AP.
To clarify, a 2.4 GHz connection generally provides longer range but at lower speeds, whereas 5 GHz frequencies offer faster speeds but cover shorter distances. The choice between 2.4 GHz and 5 GHz is often determined automatically by the end device (such as phones, PCs, Ring doorbells, Mac devices, iPhones). Additionally, network configuration (Wi-Fi/SSID/WLAN) may specify whether the network supports only 2.4 GHz, only 5 GHz, or both.
It's also worth noting that many electronic devices and appliances, such as microwaves, baby monitors, security cameras, garage door openers, and phones, operate on the 2.4 GHz frequency, which can contribute to interference. Screenshot below for the reference.
Please let me know if you have any further questions or concerns.
asaad1972
Thanks Imran for all your help!
Best regards
Ashraf
Hi @asaad1972
Have a great day ahead!!!
