ICX7150 C12P is dead. Need a replacement. How do i go about getting Ruckus to replace the switch?
Todd7
My ICX-7150 C12P switch is dead.  No lights.  Nothing.  This is my second replacement switch.  Before I contacted Wave Technology and the rep sent a replacement.   How do I now go about getting a replacement switch from Ruckus?  Thanks.
7 REPLIES 7
Todd7
I posted the video under the title "ICX7150-C12P is dead".  Not sure how to post the pics.
test
Hi @Todd7
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
