11-04-2024 11:07 AM
My ICX-7150 C12P switch is dead. No lights. Nothing. This is my second replacement switch. Before I contacted Wave Technology and the rep sent a replacement. How do I now go about getting a replacement switch from Ruckus? Thanks.
11-04-2024 11:49 AM
Hi @Todd7
Could you please try to use another Power cord just in case if that is damaged.
If that doesn't work, please try to hard reset the RUCKUS Switch, as described in the mentioned RUCKUS Lennar Knowledge Base self help article.
IF THE HARD RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED IN THE ARTICLE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Please let me know of the output.
11-04-2024 01:00 PM
Yes I tried all the above including using a paperclip to reset but nothing. No lights. The unit itself is cold. What next please?
11-04-2024 01:04 PM - edited 11-04-2024 01:06 PM
Hi @Todd7
We recommend referring to the example pictures provided below to ensure clarity in capturing the required details.
11-04-2024 02:24 PM
How do I send the pics and video?
