ICX7150-C12 stuck in Connecting phase
DLT
I've tried upgrading the firmware and it was unsuccessful. The only error within the dashboard is "*Unleashed system only supports ICX firmware version 08.0.90 or later."
I can access the dashboard through this address https://192.168.1.67/admin/dashboard.jsp?privilege=rw
The switch had an IP of 192.168.1.65 then I modified it to 192.167.1.67 and now it just says "ICX Switch is Connecting" and won't proceed to connect. Before I modified it, it said "Disconnected".
I can connect to my WiFi but the internet is really slow and in most cases it times out.
9 REPLIES 9
Hello @DLT ,
Hello @DLT  ,
Hi @DLT ,
Thank you.
Hello @DLT ,
Hello @DLT ,
