09-14-2025 07:52 PM
09-15-2025 06:34 AM
Hi @Maapi ,
From the case description, I understand that the Switch is not turning on and you have tried disconnecting and reconnecting the cables and reset.
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and a cord connected to the Switch and a working power outlet?
09-15-2025 08:54 AM
Hello - I have uploaded two videos to the location shared above. Pls check and revert.
09-15-2025 09:45 AM
Hi @Maapi ,
Thank you for sharing the requested VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
