01-23-2023 04:52 PM - edited 01-23-2023 04:53 PM
I believe that this is my issue, but I cannot get into the ICX7150 to fix it. If my AP is attached to the 7150 when I try to log in I get the message "This site can’t be reached". If I unplug the AP from the 7150 then I can get to it using the IP address, but no password will let me in. I have all the symptoms of this being my problem, but I cannot fix it.
Any help would be appreciated.
01-25-2023 02:47 PM
Success! My network is up and running with the switch and 2 APs.
Basically I used puTTY to connect to my switch using Telnet. Then I followed the steps in the "How to Upgrade a Switch ICX-7150-C12P using a USB flash drive" instructions. After I updated to Version:08.0.95hT211 (SPS08095h.bin) the switch took close to 15 minutes to reboot. After reboot I had to use SSH to get back to the switch. Telnet no longer worked.
I'm happy to help anyone else who has a similar problem.
Randy
01-25-2023 02:47 PM
Randy
07-24-2023 06:26 AM
I have the same issue; however, I have a macbook air... So I am unable to use flash drives and when I ssh into switch, it asks for a password. I tried all of the passwords they suggested; however, nothing work. I have three APs and the switch.
07-24-2023 08:43 AM
Hi @mrq201
Hope you are doing well!!!
Apologies for the inconvenience, as this case is raised by @AArthriticGamer which is very old and now closed, I will be assisting you with your own post/case you have raised. (Please refer to the link below)
