06-27-2023 01:35 PM
I have an ICX 7150 running on the latest SPR UFI code. I am trying to upgrade to the Switch firmware but I am getting an error writing to flash. I have tried from the Web CLI and the console through SSH. Each time, it copies and fails at 25% when writing. I have tried a new download and after several reboots, but no go. I have saved off the support files from the web upgrade.
07-12-2023 04:19 PM
Hi @diver19743
As your Switch version is now SPS08090k you should be able to connect your RUCKUS Switch should work with the Internet connectivity.
Now you could proceed with Upgrading the switch to the recommended UFI Version 08095g using the file SPS08095gufi.bin as described in the TFTP Upgrade guide.
07-12-2023 04:26 PM
Yes, I am not on 08095gufi
07-12-2023 05:01 PM - edited 07-12-2023 05:03 PM
Hi @diver19743
As mentioned in my previous post, you could now upgrade the switch to the recommended UFI Version 08095g using the file SPS08095gufi.bin as described in the TFTP Upgrade guide. (Please refer to the below commands mentioned in the screenshot)
Please note it is SPS08095gufi.bin in place of SPS08095hufi.bin
