ICX 7150 Won't Write to Flash
diver19743
I have an ICX 7150 running on the latest SPR UFI code. I am trying to upgrade to the Switch firmware but I am getting an error writing to flash. I have tried from the Web CLI and the console through SSH. Each time, it copies and fails at 25% when writing. I have tried a new download and after several reboots, but no go. I have saved off the support files from the web upgrade.
27 REPLIES 27
Imran_ruckus
Community Manager
Community Manager
Hi @diver19743
Hope you are doing well!!!
As per the case description, I could understand that you need assistance in Upgrading your RUCKUS ICX-7150-C12P Switch.
May I know the Current Version your Switch is running on?
And also, please help us with the screenshot of the error you are getting on CLI when you are trying to upgrade.
Please help us with the above queries and let me know if you have any queries in this regard.
Currently on 09.0.10FT213 (SPR09010f.bin)
ICX7150-C12 Router#copy tftp flash 192.168.1.211 sps09010fufi.bin primary Parameter Validation Successful Image Download started ..................................................................................................................................Image Download Done Image Validation Started Tuning CFS scheduler parameters... Compressing Console file Copying fitrace errorlog file to flash CORE_PATTERN:PID=2709 !usr!bin!img_flash_packages UID=0 GID=0 sig=11 Wed May 10 05:15:07 UTC 2023: Dumping core file to /tmp.gz, this will take couple of minutes... Image write to flash failed Wed May 10 05:15:10 UTC 2023: Core file collected as /tmp.gz, processing the core file ... Copy Operation Failed ICX7150-C12 Router#Wed May 10 05:15:11 UTC 2023: Removing the oldest core file:core_2380_img_flash_packages-5_2023-05-06_12-06-32.gz of size 56 kbytes seq 6 Wed May 10 05:15:11 UTC 2023: Calculating checksum: core_2709_img_flash_packages-7_2023-05-10_05-15-11.gz Wed May 10 05:15:11 UTC 2023: Checking integrity of core_2709_img_flash_packages-7_2023-05-10_05-15-11.gz Wed May 10 05:15:11 UTC 2023: Moving core_2709_img_flash_packages-7_2023-05-10_05-15-11.gz of size 56 KB to flash, with available space of 831636 KB... Wed May 10 05:15:27 UTC 2023: Core saved as /fast_iron/cores/core_2709_img_flash_packages-7_2023-05-10_05-15-11.gz. Moving system log files to persistent memory Copying SZ log files to persistent memory.. Done. Core collection and system log collection completed, Switch will not reboot for img_flash_packages crash
Hi @diver19743
Could you please share the output of the below commands?
show version
show flash
Lennar Home Community.
ICX7150-C12 Router#enable
Invalid input ->enable
Type ? for a list
Node doesn't exist
ICX7150-C12 Router#Show Version
    UNIT 1: compiled on May  2 2023 at 22:09:30 labeled as SPR09010f
      (33554432 bytes) from Primary SPR09010f.bin (UFI)
        SW: Version 09.0.10fT213
      Compressed Primary Boot Code size = 786944, Version:10.1.25T225 (mnz10125)
       Compiled on Mon Aug  8 11:58:28 2022
  HW: Stackable ICX7150-C12-POE
      Serial  #:FEK3849Q2H2
      Software Package: ICX7150_BASE_L3_SOFT_PACKAGE
      Current License: 2X1G
      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
    8 MB boot flash memory
    2 GB code flash memory
    1 GB DRAM
STACKID 1  system uptime is 7 day(s) 7 hour(s) 35 minute(s) 28 second(s)
The system started at 22:16:19 GMT+00 Tue May 02 2023
The system : started=factory reset   reloaded=by "factory reset"
ICX7150-C12 Router#Show Flash
Stack unit 1:
  Compressed Pri Code size = 33554432, Version:09.0.10fT213 (SPR09010f.bin)
  Compressed Sec Code size = 33554432, Version:09.0.10fT213 (SPR09010f.bin)
  Compressed Pri Boot Code size = 786944, Version:10.1.25T225 (mnz10125)
  Compressed Sec Boot Code size = 786944, Version:10.1.25T225 (mnz10125)
  Code Flash Free Space = 853499904
ICX7150-C12 Router#
