ICX 7150 Not sending power through POE
akalala
We lost power both APs aren’t receiving power after power returned. I have Reset all items several times APs and switch. I have switched cables where possible. I have attempted reboot using coms port that didn’t accept a boot load, flash attempted but failed. Boot said invalid. Not sure what I could do here.
46 REPLIES 46
again the Wi-Fi password is the current issue I need instructions on how to reset it. I can access the AP using a Ethernet cable only.
I am not able to join using wi fi
 I am in unleashed
Hi @akalala
First, we should have access to Unleased Web System. Please make sure you have access to Unleashed Web.
Please browse and login to your Unleashed account.
Select Wi-Fi Network>>Select your WLAN Network (SSID)>>Edit WLAN>>Change the password
(Please refer to the below screenshots)
You could also create a new network WLAN SSID: Please refer to the below video-
https://www.youtube.com/watch?v=eSl_8rs1QnU
The software is show the AP is functioning properly yet none of my devices stay connected for more than a few seconds. Also AP number is disconnected not sure how to reconnect it I have cycled power so far which didn’t do much. The new SSId was with same basic results does really connect. There is a DNS error as well
