06-23-2023 04:05 PM
We lost power both APs aren’t receiving power after power returned. I have Reset all items several times APs and switch. I have switched cables where possible. I have attempted reboot using coms port that didn’t accept a boot load, flash attempted but failed. Boot said invalid. Not sure what I could do here.
06-26-2023 09:00 AM
Hi @akalala
Hope you are doing well!!!
As I see from the picture you shared, seems like the ethernet cables coming from the Router or Modem/Router combo, or maybe from other devices are plugged into the wrong ports on the Switch panel. They must be plugged into any of the 12 ports as shown in the below screenshot. Please unplug the ethernet cables, plug them into the correct ports, and reboot the Switch once (disconnect and connect the switch from the power outlet).
Please refer to the short guide link below about how to connect the devices as reference:
Please check, confirm and let me know if you have any queries in this regard.
06-26-2023 05:20 PM
I have changed as the switch as recommended. I must say it was functional as previously shown. All the POE devices have amber lights the APs have no power with this change
06-27-2023 08:32 AM
Hi @akalala
We may need to check the Switch ports information from the CLI access. To check the same, please follow the below steps and help us with the output of the CLI commands mentioned in this post below.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show inline power detail
06-29-2023 07:59 PM
Here are my response to your request. I am not sure if it matter but wasn’t able to acces the switch using wireless or Ethernet only usb
06-29-2023 08:02 PM
