ICX 7150-C12P not connecting after reset
smarty_ruckus
Hello, My Switch was reset to factory default.  The SSID and password that Lennar provided for my APs dont seem to work. I am unable to connect to the switch either. I have tried connecting via ethernet cable, USB-C cable.
Unable to get the IP. I somehow managed to get to login page of the portal - 192.168.0.206 (IP assigned by my router) but none of the credentials worked for me. I have tried several combinations incuding super/sp-admin.
Please help. I am unable use the switch or APs currently and that is really frustrating.
4 REPLIES 4
pinky_ruckus
Valued Contributor III
Hi @smarty_ruckus
As per the case description, I understand that your Ruckus ICX-7150 Switch is not connecting after the reset.
Also, could you please let us know the answers to the below queries to assist you better?
1) Was there any power outage before you started facing the issue?
2) On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
pinky_ruckus
Hello @smarty_ruckus ,
pinky_ruckus
pinky_ruckus
Hi @smarty_ruckus ,
Thank you.
