11-27-2022 08:39 AM - edited 11-27-2022 08:51 AM
SYST is amber and PWR is green after replugging the power cord.
I followed the guide: https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-perform-a-Software-re...
But, the image and boot files would not load (Loading: T T T T ...) when I try update_primary and update_uboot. I'm able to ping to TFTP, and it works fine when I execute TFTP get command locally. I opened Windows firewall for UDP 69 and all ports, but still not working. Please help.
11-28-2022 09:18 AM
Hi @jolee139
Thank you for the details provided, Please try a factory reset if the issue persisted, perform the software recovery, but disable the firewall first, if still not working please provide the logs of the error while you try the software recovery. (all logs, copy and paste them here)
Factory reset steps:
Ruckus ICX 7150/7650 -ERASE SYSTEM TO FACTORY DEFAULT WITH RESET BUTTON(Tutorial video)
Yarenis Hernández
11-29-2022 05:58 PM
Hi Yarenis,
Factory reset did not work, all lights stayed as amber throughout the night.
Instead of opening the firewall ports individually, I turned off the whole Windows Firewall, and then everything worked.
My switch is back online, and all WAPs have the power now. Thank you!
I used SPS08090k.bin per guide, but this seems old, which version do you recommend for upgrade? Or is it safe to keep the current version?
11-30-2022 04:26 AM
Hi @jolee139
Great to hear that !
You can upgrade the Switch to the base version '8095g' that is the recommend from the website.
Best Regards
Fernando Vasquez
