08-06-2023 09:36 PM - edited 08-06-2023 09:50 PM
Hi Ruckus support,
My ICX 7150-C12P does not power on anymore after a power outage. Lights do not turn on and I suspect the PSU is totally dead. Tried several working outlets and different power cords. Tried the "reset" button tip while plugging in power 15-20 times and it's the same. Could you please help?
Thanks!
08-07-2023 11:11 AM
Hi @aytran12
Greetings of the day!!!
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged into a power outlet there is no power to the Switch. Also, you tried to reset the Switch. And you confirm that the Switch is plugged into a well-known outlet/power source also tried with different cords. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
