06-21-2023 09:20 AM
I had power trips and fluctuations yesterday 4-5 times. Since then switch is not working properly. Internet is very slow and connection drops intermittently. Tried restarting modem, router and switch no use still the same.
My setup : Modem -> Wifi Router -> Ruckus switch -> zoning points one in each floor.
Any help is much appreciated!!
08-07-2023 08:05 AM
Hi @rahulmandava
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS if your issue gets resolved.
06-21-2023 06:41 PM
Hi ,
I understand that there was a power fluctuations few times and after that switch is slow and drop pakets
Please help us with the below information
-Do you see any amber light indication on the switch ?
-what is the current firmware version ?
-check if there is a CPU spike on the switch
#Show cpu(5 times)
#Show cpu task(3 times)
-share us with the above output .
Regards ,
Deepu Sekar
06-21-2023 06:51 PM
Hi Deepu,
Thanks for getting back to me. I am not seeing any amber light on switch, just the regular light that we always see.
Regarding the firmware and cpu spike info, I am not sure how to check those. I am not able to connect or login to switch. Could you please help me with the steps on how I can get there ? or any other ways to resolve the issue ?
06-22-2023 07:24 PM
Hi Rahulmandava ,
Than you for your response , I understand that . you are not able to connect or login to switch.
-So you are unable to login after the power fluctuations ?
-Could you please help us with the switch model number so that i will help you to access the switch .
Regards ,
Deepu Sekar
06-23-2023 03:29 AM
I haven't tried to login in the recent past. But when I tried to once I got this issue, I am unable to either login via UI interface/Unleash app or connect via putty using IP address.
Switch model number is : ICX 7150-C12P
