12-23-2023 02:29 PM
Ruckus ICX 7150-C12P all lights flash amber once and then turn off when connected to any power outlet. I have moved the device to several different outlets and all do the same thing. I found similar posts and tried many times but it always flashes amber once, then everything turns off. There are no power surge or internet connection issues, just that the device does not power on.
Any assistance is appreciated.
12-28-2023 04:41 AM
Hi @jvillanueva
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
12-25-2023 07:01 AM
Hi @jvillanueva
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering on.
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and working power outlet? Please refer to the below pictures as an example.
12-27-2023 04:55 PM
Hi @Imran_ruckus,
I've uploaded a video and pictures demonstrating the issue to the link you provided. Please let me know if there is anything else required.
12-28-2023 04:41 AM
Hi @jvillanueva
