07-02-2023 07:17 PM
I lost power briefly and all my WAPs have stopped working, they don't have any power. I have searched for different solutions on this forum but have not had any success so far. Please help
07-04-2023 09:47 AM
So when I tried downloading SPS0808f and SPS08095gufi It didn't allow me to do so, so I utilized SPR08080f and SPR08095gufi. It gave me that error when utilizing those two. I do not know if it is the reason for the software to stop loading and crash, giving the Network error. This is the last step where it asks to “boot system flash primary” (boot the Switch with the new code)
07-04-2023 09:50 AM
Hi @Pantwi
That is the expected error when the Switch starts to reboot after performing the commands ‘boot system flash primary’ and ‘y’. After some minutes, when Switch boots up you will be able to log in again on the Putty.
And I could see from the Screenshot you shared (As highlighted in the below screenshot), you have upgraded the Switch to SPR08095g. It must be Upgraded to SPS08095g. Please Upgrade once again with the SPS08095g.bin file.
When you Upgrade successfully with the SPS file, you could follow the guide and with the above commands, and when the Switch boots up. Finish the Upgrade with the ‘copy flash flash secondary’ as mentioned in the Upgrade guide. And confirm with ‘show flash’ commands if both the partitions upgraded on the SPS08095g version.
07-04-2023 09:53 AM
Ok, and will there be any indication that the switch has booted up or should I just reopen putty once it crashes?
07-04-2023 10:08 AM
Hi
You could check from Command Prompt by pinging. Using the command ‘ping 0.0.0.0 -t’ (0.0.0.0 is just an example where you must put the Switch IP Address). Please refer to the below screenshot as an example when it starts pinging.
07-04-2023 12:10 PM
Hello again!
I was able to follow the instructions and complete the upgrade. Is there anything else to have it working again? My WAPs are still down and both of my partitions are on SPS08095g. I have completed the steps as well.
Thank you for your patience
