06-21-2023 09:20 AM
I had power trips and fluctuations yesterday 4-5 times. Since then switch is not working properly. Internet is very slow and connection drops intermittently. Tried restarting modem, router and switch no use still the same.
My setup : Modem -> Wifi Router -> Ruckus switch -> zoning points one in each floor.
Any help is much appreciated!!
08-07-2023 08:05 AM
Hi @rahulmandava
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS if your issue gets resolved.
08-07-2023 10:57 AM
Hi @rahulmandava
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
