I accidentally flashed r610 firmware on am r710
Plato12
How screwed am I? It went through and now I'm unable to get to 192.168.0.1. I used r610_200.6.10.1.308.bl7. Did i brick my device?
3 REPLIES 3
Plato12
Well. I looked for some information here and was able to console in via putty. I attempted to tftp over the r710 firmware created the command text file as a .rcks. Ran it. It took the file and all seemed well, but after a reboot it no longer sees my physical connection to my latop after a while and drops. It connects and drops and now I have no way of talking to the device. I screwed up.
Welp. I don't know what happened. Walked away for 30 minutes and came back. I had held down the reset but it didn't work. I came back after some time... 192.168.0.1 magically logged and the firmware worked. Wtf. I'm good. How. Fn magic.
Hello @Plato12 ,
Since the hard reset helped regain the access to the AP, I would also suggest you to re-flash the AP with the correct firmware.
You can download the AP R710 Unleash image from the below link:-
Latest version: https://support.ruckuswireless.com/software/3463-ruckus-unleashed-ap-200-12-mr1-refresh1-software-fo...
200.6.10.1.308  version: https://support.ruckuswireless.com/software/1686-ruckus-unleashed-ap-200-6-10-1-308-ga-software-for-...
Sarita Shekhar | CCNA | CWNA
Staff Technical Support Engineer,
Type a product name
