How to unlink 2 R310 HELP please
margio_acevedo
Hi all and happy new year. Best on this 2022.
I have 2 R310 connected on my same network (one as master, the other as slave). Is there anyway I can disassociate or un-link my slave from the master? I want them to work individually.  I want to be able to manage them apart from each other.
Any helps would be greatly appreciated.
5 REPLIES 5
sarita_shekhar
Hello @margio_acevedo,
A very happy new year to you!!
If you want the AP's to work individually on the same local subnet/network, I suggest upgrading the AP's to the standalone version.
However, if you want the Unleashed firmware, then you need to reset the AP (member AP) and move it to another network/VLAN (no inter-VLAN routing between the 2 networks).
In case, you choose to switch to standalone firmware, below is the direct download link:-
https://support.ruckuswireless.com/software/2791-ruckus-solo-access-point-110-0-0-0-2014-ga-refresh2...
AP Reset procedure:-
-- Use a paperclip, press and hold the reset pinhole at the back panel of the AP for about 30 - 40 secs.
Hope this answers your query.
Sarita Shekhar | Senior Technical Support Engineer,
CWNA/CCNA
@sarita_shekhar
Hi Sarita,
First of all sorry for my late response. I had some mails issues.
I am sorry but I have a 3 R510, would you be so kind to provide me direct link to download the Solo Version for these R510 Ruckus.
I appreciate your fast response.
Have a nice day!
Hello @margio_acevedo ,
Hope you doing good today!
Please find the direct link for the standalone firmware (latest version):-
https://support.ruckuswireless.com/software/2765-ruckus-solo-access-point-114-0-0-0-6565-ga-software...
You have a wonderful day ahead!
Sarita Shekhar | CCNA | CWNA
Hello @sarita_shekhar ,
Thank you much for your great support.
I have tried to download the firmware/link provided, but your website won't let me as it says "That file is only available to Premium Support users"
I am a regular/standard user not a premium, so how would I do in this case?
Thanks again!
