08-31-2023 01:23 PM
My R320 APs constantly gives only 250-300mbs speed whereas I checked the ethernet connnect to it gives 1000mbs.
I have three of these R320 installed and all would give lesser speed. My modem will also give speed of 950mbs.
I can't either login to Unleash app on my Iphone.
Please advise.
09-01-2023 09:55 AM
Hi @hareshoad
You are accessing the CLI of the Unleashed, Please check the IP Address of the ICX-7150-C12P Switch.
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch and access the CLI.
If you can access the Command line using the Switch IP Address should look like this:
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Please share the output of the commands shared previously or share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
09-01-2023 10:17 AM
09-01-2023 10:19 AM
09-01-2023 10:45 AM
Hi @hareshoad
The output of the commands seems normal.
Could you please let me know if All your RUCKUS APs are R320? And all the APs have the issues?
Please confirm.
Thank you again.
09-01-2023 10:58 AM
Yes all three of them are R320 and all of these are in different floor and give the same output speed.
