08-31-2023 01:23 PM
My R320 APs constantly gives only 250-300mbs speed whereas I checked the ethernet connnect to it gives 1000mbs.
I have three of these R320 installed and all would give lesser speed. My modem will also give speed of 950mbs.
I can't either login to Unleash app on my Iphone.
Please advise.
08-31-2023 01:51 PM
Hi @hareshoad
Hope you are doing well!!!
As per the case description, I understand that you have slow Internet connectivity via RUCKUS Access Points. And unable to log into the Unleashed Application.
3. Could you please let me know the light status on the ALL the 3 Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
4. On which device you are trying to log into Unleashed Application? (iOS or Android)
08-31-2023 02:05 PM
I am using iPhone for logging in to Unleash.
08-31-2023 02:17 PM
Hi @hareshoad
As per the pictures, RUCKUS Switch and Access Points lights status are normal in it's behavior.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
09-01-2023 07:26 AM
I can't upload pictures.
