03-26-2025 12:25 PM
Hello - My Ruckus AIR light is out and the system is no longer functioning after a power outage. I'm also unable to access power on the AP via the Unleashed app since the Configure.Me.... wifi is not there. Please offer a solution. Thank you!
03-26-2025 12:50 PM
Hi @DebH ,
As per the case description, I understand that your RUCKUS APs are not turning on after the power outage.
1) On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
03-26-2025 03:16 PM
Hello! On the Ruckus SWITCH - Stat, Syst, and Power lights are on -
On the upstairs AP, the AIR and CTL lights are out.
On the downstairs AP, the AIR light is out.
See below for photos. I've attached two photos of each (including close ups of each panel).
Upstairs AP
Upstairs AP - close up
Downstairs AP - close up
Downstairs AP
Thanks for your help!
Deb
03-27-2025 06:18 AM
Hello @DebH ,
From the response shared, I understand that the Switch and AP light status seems to be normal and you are unable to find Configure.Me XXXX option during factory reset.
Note: If you have multiple Access Points (APs) in your home, please go to the Ruckus Switch, disconnect from its ports the Ethernet cables of all the Access Points, except the one that you are going to work with. Once the process is finished, connect back to the Ruckus Switch the access points that you disconnected before, and they will connect into the network automatically after a few minutes.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to factory reset the AP and create new Wi-Fi network.
Please follow the article and let me know if you have any queries in this regard.
03-31-2025 06:26 AM
Hello @DebH ,
