03-27-2024 02:52 PM
moved into a pre owned lennar home. Need help setting this up.
I have ATT and ran a cat-7 wire from the back of the router to port 3 on the rockus switch. The rockus switch has a cat-5 or 6 wire connected to the access point. It connects and works, but its extremely slow. I checked directly on the ATT router and i get a Gig speed, but when connecting on the access point i get about 25Mpbs which is super slow.
Need help, and also if there is a installation guide you can send me. I would like to update the switch and access point as well at some point.
07-08-2024 05:31 AM
I replaced my ATT router and now use cable internet through spectrum. I just plugged the new modem to the rockus switch and it doesnt work any more. I try unplugging everything and trying again multiple times and nothing.
How can i resolve this issue?
07-08-2024 05:37 AM
Hi @parrillas
Hope you are doing well!!!
As per the case description, I understand that your RUCKUS setup is not working after replacing the modem.
If your ISP modem is directly connected to the ICX-7150-C12P Switch, it doesn’t work only with Modem. The connection must be from a Router or Modem-Router combo device. Could you please confirm this once?
The connection topology must be in the order:
ISP Modem>>ISP Router>>RUCKUS ICX-7150-C12P Switch>>Access Points or any device connected to 1 in-12 ports
OR
ISP Modem-Router Combo>>RUCKUS ICX-7150-C12P Switch>>Access Points or any device connected to 1 in-12 ports
Please refer to the short guide link below about how to connect the devices as a reference:
Please check the physical connectivity as per the above description and let me know if you have any queries in this regard.
07-12-2024 07:26 AM
Hi @parrillas
Thank you.
07-16-2024 05:28 AM
Hi @parrillas
Thank you.
07-19-2024 02:02 PM
Hi @parrillas
Thank you.
