03-27-2024 02:52 PM
moved into a pre owned lennar home. Need help setting this up.
I have ATT and ran a cat-7 wire from the back of the router to port 3 on the rockus switch. The rockus switch has a cat-5 or 6 wire connected to the access point. It connects and works, but its extremely slow. I checked directly on the ATT router and i get a Gig speed, but when connecting on the access point i get about 25Mpbs which is super slow.
Need help, and also if there is a installation guide you can send me. I would like to update the switch and access point as well at some point.
04-02-2024 12:57 PM
Its not letting me post pictures. But i was successful in making that change.
i will copy and paste results here
Compressed Sec Code
08.0.90BT211 (SPS08090d.bin)
04-02-2024 12:57 PM
04-02-2024 01:02 PM
Hi @parrillas
Yes, now both of your Switch partitions are on the SPS code.
Please now check the connectivity and let me know if there are any issues.
04-05-2024 01:30 PM
Hi @parrillas
Hope you are doing well.
Could you please provide an update on the status of the issue to proceed further? Please let me know if you have any queries.
Thank you.
04-05-2024 01:48 PM
so i was able to run those updates. I do noticed that when im on zoom calls it tends to freeze up quite often. Im running on wifi. The ruckus access point is about 10 feet away.
Is there a way to fix that?
