Help Connecting Router to Ruckus Switch and Access Points
Morristownjim
I need help connecting my Fios router to the Ruckus Switch and related access points.
I recently moved into a Lenar building and do not have the original logins so a reset is also needed.
I have tried a factory reset, but internet is not coming through the access points.
I would like help knowing where to connect the router to the switch and how to reset the access points to establish a new wifi password.
8 REPLIES 8
Imran_ruckus
Hi @Morristownjim
Based on the information provided, it appears that you need assistance in setting up RUCKUS and other devices.
Please refer to the below RUCKUS Lennar Knowledge Base self-help article for the RUCKUS Setup and configuration guidelines.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/RUCKUS-Lennar-Home-devices-C...
I have gone through the support pages and am still not able to get it connected. What do you recommend I do?
Hi @Morristownjim
1. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
2. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.
3. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Green lights are visible. The white cord is going from the router to the 1 in 12 ports.
ISP is working. I can log into the Verizon Router wifi. (not the Ruckus wifi)
There are 3 access points. (pictures attached)Screenshot 2025-01-01 at 3.55.15 PM.pngScreenshot 2025-01-01 at 3.55.21 PM.pngScreenshot 2025-01-01 at 3.55.27 PM.png
