12-23-2022 11:16 AM
Hello. I am a Lennar owner and have been on the community. I found an item which matches my problem exactly. It says I need an RMA and that the unit is dead. There is no way to connect to it without power. What do I do? It is a ICX 7150 C12P.
12-23-2022 11:59 AM
I hope this is what you are looking for. I have actually plugged it into 4 outlets. It will not show power in any.
12-23-2022 12:28 PM
Hi @jonmorey
Based on the troubleshooting done, and you confirm no power on, on the unit and is totally dead (no lights at all , This unit Should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post and paste it into the chat to start unit replacement.
Best Regards
Fernando Vasquez
12-23-2022 01:13 PM
Thank you Fernando.
12-23-2022 06:28 PM
I was asked to confirm my address. I responded by email because it did not say how to confirm. It was correct.
12-26-2022 08:06 AM
Hi @ jonmorey
Sure, the RMA team will contact you to confirm the mailing address.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
