08-09-2023 06:30 AM
Been in this home for a couple years now and our internet has been functioning great till a couple of weeks ago. There was an outage with our ISP and ever since they restored service nothing has been the same. We cannot stream on any wireless devices or if I'm on a teams call it will disconnect and reconnect every few minutes.
We have a Ruckus ICX 7150-C12P
We have one wired desktop and I can get on the internet but whenever I go to a website I haven't frequented I continually get ERR_CONNECTION_TIMED_OUT, if I release and renew the IP the page will load but will fail after a couple of minutes again.
I've power cycled the modem, router and switch numerous times. I've connected directly to the router and flushed DNS. None of this has improved anything. Do I have to connect via USB to the switch to look at the configuration? I can't even ping 192.168.1.1 from my desktop.
08-09-2023 10:30 AM
Hi @GimpeeBowhunter
Thanks for your response.
This issue may happen when the Switch runs on the Routing code. The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
Once you are done with the above process please share the output of the above commands.
08-09-2023 09:33 AM
Hi @GimpeeBowhunter
Sorry for the inconvenience.
Please find the below link to find the IP address of the device.
08-09-2023 09:58 AM
I downloaded the scanner and found the IP of the wireless 192.168.1.65. I put that in to a browser and I get "ERR_CONNECTION_REFUSED"
08-09-2023 10:30 AM
Hi @GimpeeBowhunter
ICX7150-C12 Switch>
show version
show flash
08-09-2023 11:05 AM
Hi @GimpeeBowhunter
As you know the IP for the Ruckus switch (192.168.1.159) please try to access the device remotely through CLI and enter the following commands.
ICX7150-C12 Switch>
show version
show flash
08-09-2023 10:40 AM
When I run the Advanced IP Scanner I only see options for Ruckus Wireless 192.168.1.159 and Ruckus-Unleased.lan
