12-20-2023 01:28 PM
My 1x C7150 would not reboot after an extended power failure. No power to Aps. Lights solid yellow and green. Pushing reset button does nothing until released then all lights flash yellow for less than a second. I’ve been several days trying to get support through the forum but am totally frustrated. I suspect I’m like most Lennar customers and not an IT expert. There is no guidance on how to use the forum. I was able to create an account and I commented on a post that had exactly the same scenario as my switch failure. I received an email from Imran Sanadi telling me to submit my own post which which I’m doing now. I think I’m the first in my Lennar neighborhood to seek help via this forum. I have successfully used support in the past when there was a dedicated Lennar help line. Several neighbors have had similar switch failures and were replaced by Ruckus. One neighbor was told that Lennar contracted for a switch that provided minimal surge protection. Lennar did not advise us that we should have a surge protector at the point of connection to the internet. You have left me in no man’s land. I have several devices I now have to run off my AT&T internet. I have little hope can get any help from ruckus or if this email will even be answered. There is no direction how to contact a local IT that I could hire. I’ve purchased a replacement switch off of eBay with no idea how I’m going to install it or even if it will come with instructions. My only hope is that I can plug it in and it will work.
12-22-2023 10:53 AM
I responded to this request on 12-21 but have not received a response. but again, since the reboot, the power light has been a steady green. All other lights are working but flashing amber.
12-22-2023 11:55 AM
You have got to be kidding me! We are right back where we were a week ago. Where the power was green...This forum is the WORST support I have ever had. What the HELL is going on with support? While I’m typing this my doorbell rings and it is FED EX delivering a new switch and two access points ( I have 3). ! It was shipped on Dec 16. From TnNguyen from San Diego. It came with no instructions on how to install or return. What kind of internal communication do you have???????
12-21-2023 05:10 AM
Hi @dlkoons
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
Could you please refer to the below link if you have the same issue and try to troubleshoot?
12-21-2023 08:46 AM
I was able to get the switch in reboot mode. How long should I wait before I try again? It’s been almost 2 hours.
12-21-2023 09:00 AM
Hi @dlkoons
Could you please let me know if you have SYST and PWR lights turned Green or if amber lights have been flashing continuously since you performed the reset?
Please confirm.
12-22-2023 10:53 AM
