07-10-2023 12:02 AM
This evening our ICX 7150-C12P switch went offline. We had no power outage or any other issues. No method gives it power, when plugging and unplugging, no nights power on. I’ve tried to reset and had the same result. I’ve tried a different power cord and same result. It seems to me that it is non-operational.
I work from home and do not have access to the internet I have to plug directly into the router cannot work of off wifi
07-13-2023 08:51 AM
Hi @ZeRoCiRcAfLiP
Greetings of the day!!!
Thank you for sharing the requested PICTURES and VIDEOS.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
